Zum Hauptinhalt wechseln
Veröffentlicht am 23. Oktober 2012 mit Core i5 oder Core i7 CPU, optional mit Fusion Drive
208 Fragen Alle anzeigen
Fan starts for one second then it turns off
Hello
my mac mini starts by its own when I plug it into power and then it keeps starting up fan spins for a second and the led light turn on for a second at the same time . I check the power supply output voltage and it is 14.8 V on four pins and 0V on four pins and one goes from 0.9 to 2.6V when the fan spinnes. I alredy checked the power button and tried to start it with only power supply pluged but it is the same I checked the logic board and it looks in good condition. Hope to find the answer?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Given that you asked this question today, I have to ask: any OS installs lately?? Catalina maybe? On an external drive perhaps?
von
Einen Kommentar hinzufügen
1 Antwort
Your power supply is bad! Here’s the needed part Mac mini A1347 (Mid 2011-Late 2014) Power Supply and here’s the guide to replace it Mac mini Ende 2012 Netzteil austauschen
Mac mini A1347 (Mid 2011-Late 2014) Power Supply Bild
Produkt
$79.99
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
But that is only 2.8V more than 12V older mac mini models accept from12-17V
von
@luka11lavric - Why does that matter?
Are you seeing any output on the display screen alters its color or you see the Apple logo? The fact the fan spins up for a short time doesn't prove the power supply is good as the load of the logic board can cause the power supply to fail. Which is what I suspect here.
As I stated I would replace the power supply, if that didn't fix it then your logic board is bad.
von
Ok on the display I do not see anything
Can you please explain what is the load of the logic board? and If I can somehow test if that is the problem?
von
And also the power supply put out all the time 14.8V even when the fan stops spinning. I do not know if that means anything
von
Think of it this way... I have a go-cart if I raise the wheels I can run the engine full out, but if I try to run it up a steep hill with a large load it won't move very fast and the engine might knockout. So the power of the engine with no load is just great! But the load you are placing it under won't let the cart go at the same speed.
This is the same with power! You can have the right voltage with the board not wired in and as soon as you do the board is not able to work.
The choices are clear it's either the power supply or its the logic board. I'm betting on the Power Supply as they often go, and is the cheaper possibility.
von
Antwort hinzufügen
luka11lavric wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 40
Insgesamt: 1,851
