Zum Hauptinhalt wechseln
The Asus Zenbook UX301LA is an Ultrabook with a 13.3-inch IPS display. It was released in November 2013 as a part of Intel's Ultrabook line.
16 Fragen Alle anzeigen
Will a replacement battery for a UX301LA work in a UX533F zenbook?
I can not find any information in the UX533F. The model mentioned in this question looks the closest to the zenbook I am looking for a battery for. Wondering if they have the same battery.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
depends does it fit the port for the battery and is it same voltage and mwh output?
von
Der Anschluß zum Netzteil wurde schon ersetzt.
von
@Ayden Aldrich
von
@Ayden Aldrich The connection to the power supply has already been replaced.
von
Einen Kommentar hinzufügen
1 Antwort
Hi @waydeph
according the specifications,
UX301LA is having C32N1305 battery, which is not fully compatible with UX533F (voltage and capacity are different). It’s compatible with Zenbook UX301LA Zenbook UX301LA-C4003H Zenbook UX301LA4500. If you want to search for compatible battery, please disassemble your laptop and check manually, what’s written on it. When you will get a PN, you can easily search for the part on the Amazon, etc.
Note:
I’ve only found, that your laptop is compatible with 0B200-03120100, 0B20003120100, C41N1814, C41PPEH batteries. The original battery is supposed to be NASC41PPEH4800B4.
For the better know, check it manually.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Wayde Hall wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 165
