Zum Hauptinhalt wechseln
Dies ist die 8" Version des etwas kleineren Fire 7. Es ist mit 1,5 GB RAM, einem schnellerem Prozessor und einem HD-Display ausgestattet. Das Fire HD 8 wurde am 7. Juni 2017 veröffentlicht.
22 Fragen Alle anzeigen
Can someone please help me locate correct USB charging port?
Can someone please tell me where I can get the correct USB port replacement for this device? I have ordered them off of eBay two separate times now and both times they have been incorrect. If anyone can help me locate the 100% correct charge port I would be very appreciative. It is for the 8th Gen model #L5S83A. Thanks, I have waited too long to fix this tablet already.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Do you have a picture of the charger port top and bottom? I can link you a compatible charger port once I see the pictures.
Is this soldered onto the main logic board or on a small daughter board?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Ben
Unfortunately that link Jayeff posted is to a USB port for the 7th Gen Fire HD 10 USB port. The correct one you need is this: Fire HD 8 L5S83A 8th gen USB port Also if you do a search for USB ports using that model you will find more of the same incorrect ports which you said you already purchased twice already. This is the only one I found that has the correct port pictured. Looks like they used a motherboard to show them matching side by side.
Hope this helps.
Best
Richard
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Yes, that is the correct model. Thanks so much I have ordered one and am glad someone could point me in right direction!
von
Ben
No problem. Glad I could help out. I notice a lot of sellers listing the wrong USB ports and I mean most or almost all of them.
Richard
von
Antwort hinzufügen
BEN wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 725
