Zum Hauptinhalt wechseln
Modell A1990 / EMC 3359. Kam im Mai 2019 mit neuen 6-core oder 8-core Prozessoren heraus.
88 Fragen Alle anzeigen
Can I upgrade myself SSD on 2019 MBP 15?
Just bought a 2019 15” MBP with 256 GB SSD. (On sale in Costco, not configurable).
Can I replace it with my older 500 GB SSD from my previous MBP?
If the answer is yes, anyone knows it it would it void Apple’s warranty?
Thanks in advance for your help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sorry, no you can’t swap out your SSD’s. While your 2015 or older Retina model has a removable SSD, the newer 2016 onward Touch Bar systems have soldered storage which can’t be altered.
But! you can remove your old systems SSD and place it within a case to use it as an external drive. That might be useful if your older system has died and not repairable OWC Envoy Pro - Portable, Bus-Powered USB 3.0 Storage Enclosurefor select Apple Flash SSDs from most 2013 to 2015 Mac Models
If you are trying to copy off your stuff to your new system there are other ways to do that YouTube - Using Apple Migration Assistant
War diese Antwort hilfreich?
Bewertung 6
1 Kommentar:
Thank you Dan for your answer.
Appreciate it very much!
von
Antwort hinzufügen
Saul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 104
Insgesamt: 27,046
