Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zum 15" Surface Laptop 3 von Microsoft, das 2019 veröffentlicht wurde.
9 Fragen Alle anzeigen
Can battery by replaced?
I know from promo videos that SSD is replacable.
How about battery?
When we are already able to open the chassis. Can battery be also replaced?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
So from the teardown video the battery is glued and is not replacable at all.
On the battery there is a warning:
Risk of fire or burning.
Do not replace, short circuit, bend, crush, puncture or modify the battery, wiring or connector.
Do not dispose of in fire or expose to high temperatures (140°F).
Do not separate or remove the battery from the backplate cover.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
If the top panel comes off easily IIRC the battery can be replaced. Hopefully it is not glued in by lots of adhesive and instead screwed in.
Bewertung 1
1 Kommentar:
This is how it should look like after removing the top cover. https://youtu.be/ucxShAm5660?t=138
von
The battery is replaceable similar to the previous versions of the surface laptop/book however the laptop 3 added a few screws as well as tape.
Bewertung 0
Antwort hinzufügen
Jakub Suchy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 892
