Zum Hauptinhalt wechseln
How do I clean my keyboard internally?
I spilled some col drink on my Laptop, I want to clean it up since I am getting weird issues with my keyboard.
I tried to open it up but it seems to be stuck in some way. So I wasn't sure if would be able to close it back. Also I dont want to mess my processor by removing heatsink or something since I have never done it before.
I really appreciate you helping me out, thank you!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @zedkasat
Here’s a link to the Hardware maintenance manual for your laptop, taken from this webpage.
The keyboard is part of the uppercase assembly.
Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove the assembly.
Usually when attempting to clean/repair keyboards you can introduce more problems than what you originally had. It is better to replace the keyboard or in this case the upper case assembly. On p.76-77 Item #2 you’ll find the country specific upper case part numbers.
Usually the part number is to be found on the underside of the assembly somewhere if you wish to verify that you have the correct number.
Once you have found the part number appropriate for your particular model variant, search online using the part number only in the search term of your browser to find suppliers of the part.
Hopefully this is of some help.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Siddhanth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,476
