Zum Hauptinhalt wechseln
Veröffentlicht Januar 2015, Der XPS 13 Laptop ist ein Konkurrent des MacBook Air, mit einem randlosen "infinity" Bildschirm mit Touchscreen Option.
Where can I buy battery for Dell XPS 13 9360?
I have tried searching for it on Dell website, not much luck there. I am looking at eBay now, would you recommend to buy one there?
  • It’s Dell XPS 13 9360 which I bought more than 2 years ago. Great laptop, still feels like new, only thing - battery lasts for 3-4 hours instead of 8-9.
Dell XPS 13 9343/9350 Laptop Battery
Thanks!
Replace a 6930 mAh battery compatible with Dell XPS13 9343 9350 model laptops. 52 Watt Hours (Wh). 7.4 Volts (V). Part #5K9CP, 90V7W, DIN02, JD25G, JHXPY. Bild
Produkt
$69.99
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
You can but just buy a newer one
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Do you mean newer battery? I am little confused, is this one used? How could you tell? Could you share any other link where I can find good battery? Thanks!
von
No that one is fine I’d buy one that has 4 to 5 star rating
von
@apple_fixnoah ok, sorry for repeating myself but this one has 4.7 rating so you would buy it right?
Also, this one, for example, is more than 2 times expensive, what can be the reason? Is this one knock-off (maybe good but still knock-off) or what?
https://www.ebay.com/itm/NEW-OEM-GENUINE...
von
It could be a better quality one I would buy it
von
Antwort hinzufügen
Konstantine Shengelia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 363
