How to replace a Home Buttom
How Can i replace a bad home buttom on aiphone 3gs.
Ist dies eine gute Frage?
Albert,
Follow the front panel replacement guide here:
iPhone 3GS Front Panel Replacement
When you get to steps 12 thru 18 you will see the home button and all you do is remove the home button itself and the ribbon cable / switch under the home button is adhered to the frame so use a spudger to unstick it, slide it out through the case and the new one slides in and is attached with adhesive.
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 1,343
