Zum Hauptinhalt wechseln
The HP ProBook 450 G2 is a 15.6-inch business laptop marketed toward private and business users.
10 Fragen Alle anzeigen
How do you clean the fan?
I’ve had my laptop for 4 years now and the fan is always ramped up at max, making it very loud and whinny. I have never cleaned it, but I feel like its about time I did, and get to see if that problem goes away. Thoughts?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
remove the bottom cover and start cleaning, you should also replace the arctic grease behind the processor if it is the type to come out. The fan may actually need replaced. Dont use 3 in 1 oil, WD40 will only last a little while.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Samwel Ehr marsha  get the service manual from here Page 75 explains how to get to the fan.
War diese Antwort hilfreich?
Bewertung 6
Antwort hinzufügen
Samwel Ehr marsha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 762
