Zum Hauptinhalt wechseln
Model A1311 / Ende 2009 / 3.06 oder 3.33 GHz Core 2 Duo Prozessor
310 Fragen Alle anzeigen
Is ODD fan necessary after removing ODD
Hello, I opened up my computer to clean out dust for the first time in a decade and I also removed the ODD because it’s no longer operating. Should I still keep the ODD fan installed or can I remove it? I don’t know if it is needed to cool other parts of the computer but I don’t want to put it in if it’s gonna over speed because of some error from the ODD being gone
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
SMC requires the input of the fan to properly work. Are you sure the fan has failed? If it has you’ll need to replace it otherwise your system will ramp up the other fans to make sure the system doesn’t overheat (Safe Mode)
So simply put yes you need the fan and yes you’ll need to replace it for your system to work properly iMac Intel 21.5" (Late 2009-Mid 2011) Optical Drive Fan
iMac Intel 21.5" (Late 2009-Mid 2011) Optical Drive Fan Bild
Produkt
$29.99
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
The disc drive (ODD) is what failed and I removed that just for ventilation sake and I don’t plan of replacing it. The fans works just fine, I’m just wondering if I need to put that back in if I’m not going to have the disc drive in there.
von
Yes! Put the fan back.
von
Antwort hinzufügen
Jonathan Nyquist wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 160
