Zum Hauptinhalt wechseln
Troubleshooting, device, and repair guides for the 2016 Samsung Galaxy J7, model number J710.
Is there a possibility for a charger port to burn?
(So actually my phone is J7 Duo, but its just isn’t there.)
Is there a possibility for a charger port to get toasted when the socket i’m using kind of exploded, or sparked?
I’ve tried different wires already, but my phone just won’t charge, and i’m kinda losing hope because when I used those wires on a different phone, it works. (So i’m kinda bummed and sad)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes It is, is one of the common problems on the Smartphone-Repair World, can be broken or a fuse is burn, in this particular model if the charging port is bad or broken you will need micro soldering skills for replacing Charging Port because it is attached to the Logic Board / Motherboard.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Elyxha Denisse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 42
Insgesamt: 399
