Flickering Lines on the screen
Flickering lines on the bottom of the screen and black bar on the right side. Appeared all of a sudden, restarting hasn’t helped.
Ist dies eine gute Frage?
This is a known issue with the T-CON board over heating due to the rear vents being blocked. Hopefully you haven’t damaged the board from cooking your system.
Sadly you’ll need a new display to properly fix this as the T-CON board is attached to the LCD
Here’s the needed part:
Here’s the guide to put it in MacBook Pro (15 Zoll, 2017, Touch Bar) Display tauschen
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 663
