Maytag Bravo X stuck with 13 on timer and wont start.
tried to use my washer today and the timer started at 13 and locked me out of the settings how do I fix that
Ist dies eine gute Frage?
I found out that the lid switch wiring was faulty (loose) at the circuit board after touching everything I wiggled the connector in back and this restarted the timer. my machine sits outside and it must have gotten a bad connection. because this made it work again done 5 loads and still going strong. timer on 13 is bad lid switch connection
War diese Antwort hilfreich?
First unplug the machine for five minutes to allow it to reset. Then plug it back in and see if it throws any error codes.
Did the code reset on your washer?
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 947
1 Kommentar
13 is loose lid switch connection at circuit board
von babiespapers
