Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
iPhone stuck in recovery mode
My phone started randomly shutting off and then on again. Every time it would turn on, it would be on for a minute or even less, turn off again and then start turning on again on its own. I tried fixing it by getting it into recovery mode - that didn’t work even though I tried doing it multiple times. At some point, my phone just got stuck in recovery mode, and now it won’t turn on at all.
I also tried connecting it to iTunes and updating iOS while in recovery mode, but every time I would get some sort of error, usually error 75.
I have no idea what else to do, and I would like to avoid putting it into DFU mode. Any help would be greatly appreciated. Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If a new battery and charge port doesn’t improve the situation, then your next ‘most likely’ fault would be damage to the tristar usb recognition chip which can cause these symptoms. Changing tristar is not a DIY job, but can readily be done by any competent microsolderer. If not tristar, then it can be failure or corruption of the flash memory chip.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
anastasija wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 2,221
