Zum Hauptinhalt wechseln
Das Samsung Galaxy J7 ist auch als Samsung Galaxy J7 Duos bekannt, es hat einen doppelten SIM-Karten-Slot. Es kam im Juni 2015 heraus und verfügt über ein 5,5-Zoll-Kunststoffgehäuse und ein 720 x 1280 Pixel großes Display sowie Android OS, v5.1. Es hat eine 13-MP-Hauptkamera und 5-MP-Sekundärkamera sowie einen herausnehmbaren Li-Ionen-Akku mit 3000 mAh.
170 Fragen Alle anzeigen
Accidentally spilled some water on my Galaxy J7 2017
The touchscreen and the power button dont work. The phone is turned on and I cant turn it off. I set it a year ago to never timeout. I put it in rice now. After 15 minutes I saw the screen started stuttering (idk if its the right word for it i mean doing random moves) but didnt fix. My guess is I will need to bring it to the repair service, but is there any way to turn it off? Also Im not good at teardowns and this device is a hard example.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@musava_ribica start by pulling the battery Samsung Galaxy J7 Battery Replacement which is easy. Skip the Rice. It’s an urban myth that does absolutely not do anything.
The very first step I would take is to disassemble your phone. Use these guides Samsung Galaxy J7 to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage. The longer you wait the less likely your chances to revive this phone.
iPhone Bild
Anleitung
iPhone Wasserschaden reparieren
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Samsung Galaxy J7 Battery Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
1 minute
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
should i do it even if my phone is turned on?
von
Yes. Removing the battery will turn your phone off!
von
Place your phone in a safe, dry place. Allow at least 48 hours for the liquid to evaporate before reinserting the SIM or microSD cards or turning on the device. Placing your phone in a plastic bag filled with uncooked rice facilitates the evaporation process. Also, dry your phone with a hair dryer.
Regards,
Lewis
Bewertung 0
Antwort hinzufügen
Dario Vuksan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 185
