Zum Hauptinhalt wechseln
Veröffentlicht Januar 2015, Der XPS 13 Laptop ist ein Konkurrent des MacBook Air, mit einem randlosen "infinity" Bildschirm mit Touchscreen Option.
Four flashes. Battery isn’t recognized by laptop.
Just replaced my dying battery with one from ifixit.
The white charging light appears when I attach the ac adapter, then I get four orange flashes.
The internet says this means a bad battery. Did I receive a bad battery or is there something else that could be at play here?
EPILOGUE: I followed the recommendation, started the process. For giggles, I unplugged and repeated the connection and realized it had been user error. Fixit troubleshooting 101.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hi,
What happens if you leave it on charge for a while, does it stop flashing?
Have you tried re-installing the old battery to check if the problem is still there, assuming that it didn't do this before?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
EPILOGUE: I followed the recommendation of jayeff and started the process of confirming connectivity with the old battery. For giggles, I unplugged and repeated the connection and realized it had been user error. I just hadn’t pushed the connector in far enough. Shame on me. Fixit troubleshooting 101.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I am having the same problem you've described, but with no luck on playing with the connection. The old battery re-connected just fine, but the ifixit battery didn't. After hours of sitting plugged in, the flashing orange light continues, and when I unplug the computer it immediately dies. So the battery isn't connecting. Makes me wonder if i got a bad battery.
von
Hilfreichste Antwort
discosammy enter the "Epilogue" as an answer so we can mark this question as resolved.
Bewertung 1
Antwort hinzufügen
discosammy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,273
