The LG G Pad 7.0 LTE was released in 2014. It is an Android based tablet produced by LG. This tablet has a 7 inch screen and a 1.2 GHz Quad-core processor. The model number is V410.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
6 Kommentare:
Hi,
Bit more information is required.
Have you turned on BT in the tablet's Settings menu?
Have you set the headphones in 'pairing mode"?
Can you 'see" the headphones in the tablet's BT settings available connections area?
If so can you connect the headphones to the tablet?
Have you increased the Volume level from the tablet?
It is a BT compatibility problem between the two devices.
i have the same problem with the BT in my car. It works OK with one phone but not another (both the same Android OS "version" but have different manufacturer's version of the OS) and the phone that doesn't work with my car works OK in another car. Very frustrating.
Hi,
What have you tried?
von jayeff
Yes and still no audio
von Nate Dorsey
Hi,
Can you try different BT headphones to prove whether the problem is in the headphones or the tablet?
von jayeff
These Bluetooth headset works in another phone, also I tried another Bluetooth sound bar and it worked on this tablet , like really !!!!
von Nate Dorsey
Hi,
i'm afraid that I have no answer.
von jayeff
1 weiteren Kommentar anzeigen
