Zum Hauptinhalt wechseln
The Dell 1710n is an office laser printer released in 2011.
8 Fragen Alle anzeigen
How to remove white 'scuff'marks on print jobs?
Had no problem until this week - my 1710 printer is not printing clearly, there are scuff marks that repeat in 'white cloud' shapes down the page in regular intervals. I have pulled out the printer catridge etc and have wiped out excess toner internally via the front panel. Is this problem caused by a piece of paper stuck on the rollers ?? The dell toner cartridge is hardly used, as new.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This is usually caused by a scratched drum. If not, then you exposed it to too much light or you exposed it to light or touched it.
Usually light damage is permanent. You probably need a drum at that point. However, if you let it sit in the printer and not use it, it may recover. It probably won't, but it does have a chance. It's better then assuming a drum dead and that's like 50-60.00 to replace dead. Scratches are always cases a drum rebuild or a new drum is required.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Johanna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 12
Insgesamt: 1,148
