Zum Hauptinhalt wechseln
2.4GHz, 2.7GHz, oder 2.8GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
274 Fragen Alle anzeigen
New SSD / RAM / Battery on early 2013 MacBook Pro 15''
Hello everyone,
I am Pietro, an Italian student based in London. I am new to the forum, I registered to ask for some suggestions on how to boost the performances of my 6 years old Macbook Pro.
I have a
- MacBook Pro (Retina, 15-inch, Early 2013, 256gb)
- Processor: 2.4 GHz Intel Core i7
- Memory: 8 GB 1600 MHz DDR3
- Serial Number: C02LJ1X2FFT0
I have tried to clean it from the cache, reduce the files, applications, etc but the performances of the notebook are still poor: for instance, I can't open TripAdvisor's webpages because "they use a significant amount of memory" as Safari tells me.
A friend of mine bought from Amazon for 70€ and installed himself a new SSD on his 2011 Macbook and told me that the notebook's performances are basically as if it was new. I am therefore considering doing the same thing: changing the SSD with a new one and possibly also changing the RAM and the Battery (which has significantly deteriorated with use and now has a very short autonomy.
I am wondering which intervention would be more effective to improve the performances: new RAM or new SSD? And what capabilities of the new RAM and SSD should I take into consideration?
Thank you in advance to all that will help me.
Pietro
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Apple MacBook Pro 15-Inch "Core i7" 2.4 Early 2013 Specs
Identifiers: Retina Early 2013 - ME664LL/A - MacBookPro10,1 - A1398 -  2673
https://everymac.com/systems/apple/macbo...
The RAM cannot be upgraded.
Here are the storage sticks available for your machine:
https://eshop.macsales.com/upgrades/macb...
Here’s how to install a new one:
MacBook Pro 15" Retina Display Anfang 2013 SSD tauschen
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you very much for your answer! Would you say it's going to be enough to boost the performance of the notebook or I am wasting time and money?
Would you recommend
- the" OWC 250GB Aura Pro 6G" ($70, https://eshop.macsales.com/item/OWC/S3DA...)
or
- the "Apple Genuine 256GB SSD / Flash Internal Drive Upgrade for Mid 2012 to Early 2013 MacBook Pro with Retina display" ($45 https://eshop.macsales.com/item/Apple/SS...)?
Thank you again,
Pietro
von
Your machine should have shipped with a 256 GB SSD. Go with a larger one. To retain your old drive as external storage and to facilitate transfer of data, buy a stick with the Envoy included.
To get you to 480GB I'd go with this one:
von
mayer, thank you very much for helping out. The SSD of the link you sent says "for MacBook Pro w/ Retina Display (Late 2013 - Mid 2015)". Being mine an "early 2013" would it still be compatible?
In general, do SSDs deteriorate with time causing worse performances? In other words, is the substitution of the SSD likely to make my Macbook faster?
Thanks again,
Pietro
von
Antwort hinzufügen
pietroguglio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 56
Insgesamt: 3,456
