Zum Hauptinhalt wechseln
Angekündigt im August 2017. Das Galaxy Note8 ist der Nachfolger des durch Rückruf bekannten Galaxy Note7. Erhältlich war das Note8 im September 2017.
140 Fragen Alle anzeigen
Black screen, no drop damage
My note 8 screen suddenly stopped working, no drops or known damage of any kind. Just a totally black screen but everything else seems to work, light blinks, it rings when you call, everything. A repair shop that was planning to replace the screen said the screen is ok but the screen power chip is bad. Does anyone know of this is on the logic board or daughterboard? Also, if i replace the logic board, will i lose my data?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Brady Martin “if i replace the logic board, will i lose my data “ yes you will. Your data is stored on a memory IC which is part of your logic board. Not sure which “power chip “ the person you took it to is referring to. U900 is the display PMIC which, in principle could qualify what that person is suspecting. It is on the logic board. I’d suggest you go ahead and follow the troubleshooting as outlined here
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thanks so much for the helpful response. I'm just getting into component level repair, so this should help a lot. I'll give it a try
von
Antwort hinzufügen
Brady Martin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 4
Insgesamt: 183
