Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
95 Fragen Alle anzeigen
Water Damage cleaned up but screen not working
Hi
Have followed guidance from other answers. Ive completely dismantled the phone after water dammage. Cleaned every connection with 99% Isopropyl alcohol, ive submerged the board in it also and recleaned. I've removed the heat shields to clean as much as I could. I bought an ultrasonic bath and cleaned the board with the isopropyl alcohol in it also, I ran a few cycles.
I replaced the battery, the charging port and the screen. The original screen was cracked to begin with.
On booting up the new screen is still black and won't display anything. The phone is responding to the home button with vibration, vibrates when plugged into charge etc … but nothing on the screen.
I'd like to back up the data at the very least but the phone hasn't been paired with a computer and need the screen to do this so I'm stuck.
Any ideas? Could something have gone on the board that's preventing the new screen from working?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Do you know how to test the backlight circuit etc?
von
I don't but could follow a guide if there is one?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like the display connector got damaged for sure, but if the digitizer still works, you can use a lightning to HDMI adapter to pull the display on a monitor, and just use that to navigate around the phone to do a backup.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
That's a creative solution!
Can you back up via USB while the HDMI adapter is connected though? I'm sure I could use iCloud backup if not and use something like mega to backup photos.
I'll order one of those to test that out and let you know how I get on.
Ideally would like to have a working phone again too but I'd settle for a backup.
von
Tried a second screen but no joy again.
Have ordered the HDMI adapter will update when it arrives
von
Antwort hinzufügen
gazz57 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 69
