Zum Hauptinhalt wechseln
Released April 2014; identified by model ILCE-6000. A mirrorless, digital E-mount camera with APS-C Sensor.
19 Fragen Alle anzeigen
What's the best way to clean battery contacts with a Sony a6000?
Today I got a “for parts” off ebay and the seller stated that when he put in a Sony battery it would display: Batterie incompatible. Utiliser le mobèle correct. Then promptly turn off. I thought it might be an easy fix since I have had an issue with a few batteries I got off Amazon a few years ago. Neither battery would work in my nex-3n at the time. I looked up the issue with the batteries and found the identical batteries on a thread where fake batteries on dpreview:
UPDATE on fake Sony NP-FW50 battery
With the “for parts” camera it doesn’t matter what working battery I put into it (Sony or Wasabi), it still displays the same incompatibility message. I have looked into this issue and what I have found out is that there’s a bad connection between the battery and battery contacts:
The CHARGE light on the battery charger flashes when charging the battery pack.
Cleaning battery/camera contacts and connectors etc.
I tried to clean the contacts with a dry paint brush and using same paint brush with rubbing alcohol and no matter what the camera still displays the same message. I have also thought of using a pencil eraser I have wondered if I have to replace the battery contacts, so I looked to find a take apart which I found on youtube:
Sony A6000 Disassembly
Which shows what I may have to do to replace the battery contacts if I’m unsuccessful with cleaning the battery contacts.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I took apart the camera and where it needed cleaning is on the mother board contacts, the connecting wire ribbons but didn't look like the main battery connects required cleaning. I found the Ifixit: Sony α6000 Motherboard Replacement to be the best way to disassemble the camera as well found KONTAKT but haven't gotten any yet because it seems to be a cleaner that requires good ventilation. I’ll try the How to fix corrosion on motherboard. with isopropyl alcohol 99% but looking at the Motherboard Replacement seems that parts might get damaged with the whole logic board soaking technique. If the isopropyl alcohol 99% technique is unsuccessful I will get the KONTAKT cleaner.
von
Both of isopropyl alcohol and Kontakt require good ventilation. But it is enough just to open window a bit and leave it for a while after 30min.
Also you can try ultrasonic bath with isopropyl.
Suppose problem can be somewhere else like battery controller.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You can use for contact cleaning some solution. I prefer (it is avaiable from local store) Cleaner KONTAKT 60 by KONTAKT CHEMIE. You can add some acid to it if it is a strong rust vinegar or lemon juice. Don’t forget to wash out acid. For washing electronics I use isopropyl spirit rather then ethanol.
As for rubbers I prefer not to use any because you can easly scratch electroplated layer of nickel, and then oxydation occurs much faster.
BTW, I don’t know about your camera, but my canon accepts batteries with some special chip only. Otherwise it can’t show level correct.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
georgevp1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 437
