Zum Hauptinhalt wechseln
Der Acer Nitro 5 AN515-53-55G9 ist ein Laptop für preisbewusste Gamer, welche 2018 auf den Markt kam. Der Laptop verfügt über einen 256 GB SSD Speicher, eine Nvidia GeForce Grafikkarte und einen Intel Core i5 Quad-Core Prozessor zu einem günstigeren Preis als bei den meisten Gaming Laptops.
Wifi adapter keeps dying
So just yesterday I went completely offline and when I checked the wifi settings, it just showed up with no wifi connections and when I hit the troubleshooter, it said there were driver issues, yet it couldn’t fix them. I downloaded and installed the drivers from the acer support website, but it just happened again this morning, is there a way to fix this for good? It’s only just started happening ever since I updated the system to that whole new windows 10 version where everything’s changed and I can’t revert it!
I’m thinking these may be helpful:
Thanks for all the help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @theandroidkid
Try the following:
Uninstall the WLAN adapter in Device Manager
Clear the TCP/IP stack by performing a TCP /IP reset
Restart the laptop.
Check in Device Manager that the WLAN adapter has the latest WLAN drivers installed. If not, then install them
Check if the problem is resolved.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Okay, I have tried it, only time will tell if it was successful.
von
okay idk if this would fix mine but it kinda sounded like the same problem for me so I went ahead and did this hopefully I didn't really mess something up but I have bad connection when I move anywhere and it's not my internet or the hot spot so I thought it was my computer plz tell me you know of something else to update on my drivers or something i should do
von
@Cody Kost
It may be a loose antenna connection in the laptop.
if you go somewhere else and you know where the WiFi router is physically located (not easy to know this I know, unless you mean at home) try using the laptop as close as possible to the router. If there 's a good stable connection its looking like an antenna problem.
What is the make and model number of the laptop?
von
I just bought an Acer nitro from a pawn shop and to make a long story short, the wifi adapter (radio) is wore out. I'm waiting for them to fix it but looking at the prices on eBay, I would say just replace the card. It's about as easy replacing memory. The prices I saw were lesss than $15. I was a network administrator in my career (disabled now). I would replace the card before attempting anything with the antennas because on those gaming laptops to antennas wrap around the edge of the laptop itself and it can be a nightmare. Just my two cents. Hope it helps. Good luck
von
Antwort hinzufügen
Bryn Trainor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 1,178
