My drives are not being recognized.
My drives are not being recognized. I have tried making sure the drives are plugged in, I have tried using a different connector, I have tried everything. The drives use the PATA Drive interface and also has support for SATA. Not even my dvd drive is being recognized. I have also tried going into the BIOS to make sure the drives are enabled. Everything seemed fine despite this matter. Ideas?
Ist dies eine gute Frage?
4 Kommentare
Hi @proelectronics ,
All your drives or only the secondary drives and the ODD?
Just verifying that all drives are being detected in BIOS, is this correct?
von jayeff
None of the drives are showing up. Not even my boot drive in which has windows installed.
von Richard Smith
Hi @proelectronics
So none of the drives are showing up in BIOS.
Can you hear (or feel) the drives spin up when you turn on the desktop?
If not check that there is +12V power supply feeding the drives
If yes check the +5V power supply to the drives
von jayeff
The drives are not spinning. Also, when i upgraded the power supply, i thouroughly made sure there is a 12 volt power supply in there. plus, after the power supply was upgraded, it was running just fine. Now, it is not doing so well.
von Richard Smith
