Zum Hauptinhalt wechseln
Apples Smartwatch der dritten Generation mit optionaler Mobilfunkverbindung, veröffentlicht am 22. September 2017
197 Fragen Alle anzeigen
Apple Watch series 3 no touch after screen replacement
I recently replaced the screen on my Apple Watch series 3 Nike + edition. The screen comes on and the buttons work but there is no reaction from the device when I touch the screen. I have tried force restarting it dozens of times and it has changed nothing. The old broken screen does not work at all so I believe that trying to use the old digitizer will not work. Anyone have any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Sounds like either the display assembly was defective or the cable connection from the SIP was not fully inserted and latched or was damaged.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I have tried reseating the cables a couple of times and that hasn't changed anything, unfortunately, so I am beginning to wonder if there is another component that might be damaged or if the unit is now useless
von
I went back and tried your solution and to my surprise, it worked! I can't believe it was that simple of a solution, thank you!
von
What exactly was the solution? @Blake Russell
von
@chi.areadj - Either the cable was not fulled inserted or the display unit was defective.
von
Blake what was it that you did exactly? I am having the same problem…I can’t get touch to work. The touch cable appears to be seated into the connector…I’m stumped
Bewertung 0
1 Kommentar:
Hi Jerrod, did you ever resolve the problem with your watch? I have the same issue.
von
For me the solution was update the firmware and after the touchscreen start to work fine.
Bewertung 0
1 Kommentar:
I purchased one of these sapphire screens for series 3. Screen works but in constant restore loop. Firmware upgrade fails each time also
von
Antwort hinzufügen
Blake Russell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 84
Insgesamt: 4,006
