Zum Hauptinhalt wechseln
Release date: August 22, 2017 Model: 6D20
Leapfrog Leappad Ultimate factory reset without password
I bought a Leapfrog Leappad Ultimate at auction. It has a lock code that I don't know. Is there a way to bypass or reset without the passcode? 196 backspace 87 doesn’t work.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare:
Can't reset password with 197 87
Any other
von
Did anyone ever figure this out because I’m having the same issue and I don’t have a computer to hook it up to
von
Einen Kommentar hinzufügen
2 Antworten
I believe you hook it up to the computer, then use leapfrog’s software, Leapfrog Connect, which will allow you to link it to your account and reset the passcode. Doing this does wipe out any downloaded content so you won’t get what the previous user had on there.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Did anyone ever figure out how to unlock the leappad ultimate im having the same problem
von
Try holding the power button and volume up button down together till the device turns off and then back on. It will hopefully bring you to a coding area click the reset and follow the prompts. Worked for my leapfrog academy
Bewertung 0
Antwort hinzufügen
Hubstuckey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 133
Insgesamt: 12,176
