Zum Hauptinhalt wechseln
Das Mate 20 von Huawei wurde im Oktober 2018 in London angekündigt. Das Modell HMA-L29 ist verfügbar mit 4/6 GB RAM und 64/128 GB Speicher.
9 Fragen Alle anzeigen
Is my phone hard bricked?
Hi, all just wondering if my phone is hard bricked or not since I can’t find any information on my specific device it won’t turn nor vibrate the red light goes out and return after 10 seconds press of power button and the hard rest process. Is there any solution to it or is the phone dead?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Try this link and check if you can force flash the stock ROM
Here’s a link to the available ROMs
War diese Antwort hilfreich?
Bewertung 2
8 Kommentare:
Hi, so my phone is hard bricked even though I didn't mess around with the software?
von
Also, How will I be able to flash ROM when there no connection to my pc?
von
Hi,
Does the phone indicate that it is charging properly when the charger is connected?
You don't use a PC connection.
When you do a "force flash" the firmware files are stored on a SD card which you have pre-loaded (load into the root directory of the SD card) from a PC or phone or whatever and then you insert the SD card into the phone.
It is all there in the instructions
von
well, the condition regarding the charging thing it's weird the light comes on but now it flashing and when holding the power the phone vibrates but then the light goes back to solid again furthermore when it vibrates the screen comes on showing low battery but that's all once the solid light comes on the phone goes back the original condition black screen and no response.
Thank you for your help.
von
Hi,
What happens if you just connect the charger and do not press any buttons?
Does it charge smoothly up to full charge or does it stop charging, start and stop etc?
Have you tried either starting the phone or doing a hard reset with the charger connected in case it is a faulty battery that is the cause of the problem?
Can you get into the phone's recovery menu area OK with the charger connected and switched on?
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
Tony Vox wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 16
Insgesamt: 2,473
