Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
873 Fragen Alle anzeigen
Is my logic board dead? Saw small flame on iPhone 8 cam ribbon.
I forgot to unhook the battery. Self teaching repairs. IPhone 8 front can ribbon flamed up a bit and the screen had worked prior. Did I damage the logic board, battery or screen… or all 3? Won’t turn on at all now. Suggestions for a device to test screens? Device to test separated logic boards? Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Thank you. Any suggestions on a reputable micro soldering company would be appreciated.
von
@nameistrey You should give your approximate position so that someone may possibly give some suggestions.
von
I’m located in Austin, TX
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sparks and smoke point to a short to ground and burnt components. Try unplugging both cameras connectors, disconnect and reconnect battery and see it the phone starts without those parts in place. In case it doesn’t the logic board sustained damage and needs to be fixed at microsoldering level. If it boots, plug back the rear camera, replace the front camera assembly and reassess damage. There’s not much else one can do beside replacing parts on an iPhone without professional tools and skills.
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
S. T. Wood wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 44
