Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
Won't Charge, Won't turn on, Won't display the battery icon
Hey all, so this is my brother’s iPad that we’ve been having trouble with. As a quick backstory, he dropped it a couple of days ago. Since then whenever we’ve plugged it in, the lightning bolt symbol appears and the battery bar turns green, yet the battery keeps trickling down. We’ve already tried a hard reset and confirmed it was not the cable nor the adaptor itself, and in fiddling with it, it has now run out of battery. At first, the battery showed up as that red ‘low battery’ icon (and plugged in it didn’t have the charger icon, so again, it indicated charging). But now that won’t even show up. It’s just a black screen no matter how many buttons we press or how many hard resets we attempt. As of right now, it’s a brick with zero sign of life. What do you think could be wrong?
Thanks for reading :) x
P.S: I cleaned out the charging port as well with some paper, so that’s all dandy too.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Alex C, you probably have a dead battery in your brother’s iPad. What I recommend you do is get a battery replacement form apple or a local third party repair shop. You can do by yourself using this guide: iPad 6 Wi-Fi Akku austauschen, but it is extremely difficult and requires you to disassemble the whole iPad. If you are going to do this yourself, make sure to get the right tools and kits and follow the guide step by step. I would get the Essential Electronics Toolkit to get most of the tools needed.
I hope you can fix that iPad!
-Alex
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair. Bild
Produkt
$29.95
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Even with the battery being dead wouldn’t the iPad still power up when staying plugged in 24/7, just like a laptop with no battery connected? I’m having the same problem but trying to rule out if it’s the charger port or the battery itself.
von
You probably need to replace the charging port inside of the iPad because it might have been damaged, but if that’s not the case then you need to replace the battery instead.
Bewertung 1
Antwort hinzufügen
Alex C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 38
Insgesamt: 3,306
