Zum Hauptinhalt wechseln
This laptop was released in 2016. Model Number: i5368-10024GRY ASIN: B01F3R99HY. In order to properly repair this device, screwdrivers, iFixit Opening Tools and spudgers are necessary.
How do I replace the keyboard?
Is there a guide to replacing the keyboard on an Inspiron 13 5xxx series laptop?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @gordol ,
Here’s a link to the Inspiron 13 5000 Series 2-in-1 Service Manual
The keyboard is part of the palmrest assembly which means that you’ll nearly have to completely dis-assemble the laptop to get to it.
Scroll to p.81 to view the necessary pre-requisite steps and then the procedure to remove / replace the palmrest assembly and keyboard.
Don’t know with your model but on other laptops where the keyboard is part of the assembly, if you wish to replace the keyboard only, you’ll find that the keyboard is permanently attached and has to be literally snipped off the palmrest and a new keyboard glued back into place.
Here’s a link that may be of some help in that regard.
Keyboard replacement possible? Dell Inspiron 3147
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thank you. That is what I was looking for, but could not find.
The replacement keyboard I got off of Newegg claims to be for this and other 13-5xxx models, and appears to screw in. We'll see. Right now, I'm stuck on stripped screw heads on two of the screws that hold the motherboard on. Dell torqued them down too tight. I have a set of precision extractors on the way from iFixIt.
von
Follow these steps:
  1. Unscrew the screws from the backside of your laptop.
  2. Remove the backside of the laptop.
  3. Pop-out the keyboard using a spatula (or a similar instrument) from the corners.
  4. Replace the keyboard.
  5. Follow the above steps backward from step 3.
Hope this helps!
Regards.
Bewertung 0
3 Kommentare:
Hi @judysmith712 ,
You're braver than me working inside a laptop without disconnecting the battery first ;-)
von
Oh I forgot to mention that. Sorry. My bad.
von
Um, there's a motherboard, battery and hard drive between the back case and keyboard.
von
Antwort hinzufügen
Jeffrey Kaplan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 37
Insgesamt: 2,290
