Zum Hauptinhalt wechseln
Kam im Juni 2012 auf den Markt / Intel Quad-Core i7 Prozessor mit Turbo Boost / bis zu 1GB DDR 5 Video RAM
597 Fragen Alle anzeigen
How can I fix the camera chip on the motherboard?
Hi guys,
while changing my wifi antenna on my MacBook, I unfortunately jammed the camera cable under the hinge of the screen.
After the third usage it was smelling a little bit for a few seconds but I did not think anything bad until I tried to use the camera - it did not work. The chip is black (see photo) and I have no idea how to fix this.
I already tried replacing the screen but it did not work out …
What should I do?
Thank you so much for answers!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You have to replace that small burned component (micro-soldering skills required). If you don’t have experience take it to a computer repair shop. Replacing that component will take 5 mins, and additional inspection looking for short circuit another 10 mins.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thank you so much!
von
Can you tell me what a reasonable price for this repair would be? Just to see if it's worth it to use the camera again and to make sure that I am not scammed.
von
I good tech can charge you by hour from $25 to $35 + Component Cost $ 0.10 , Now if you computer has more problems he will inspect it and can be more if a chip or more components are bad.
von
Antwort hinzufügen
Jonas Kurth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 314
