Did anything happen to the device in the days and weeks leading up to this issue, such as a drop, a repair attempt or contact with water?
Assuming this was a spontaneous failure, it is probably a failed component on the logic board. The iPhone 7 is prone to several issues after repeated minor drops and flexing over the course of its life. It could also be a dead or dying battery or modular component.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good.
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair. Sometimes the fix can be straightforward (i.e. a blown filter) and relatively economical.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
