Zum Hauptinhalt wechseln
Der iMac G3 war in den Farben "Tangerine", "Blueberry", "Lime", "Grape" und "Strawberry" erhältlich.
How do I install the MacOs?
Change the original 4GB HDD of this model to an 80GB one. But I can't install the system to use it again. I light it and the “?” Icon is flashing. Download and burn discs with MacOs 9, 8 and I can't make it boot from the CD. As I read it was to keep the letter "c" after the ignition but does nothing. I would greatly appreciate your help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
What is the make and model of the drive you installed?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Partition the drive with one 8GB partition, and one 72GB Partition onto your IDE drive (do not use a SATA drive). Install the system onto the 8GB partition.
iMac G3 Model M4984 Hard Drive Replacement
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Horacio aparo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 248
