Zum Hauptinhalt wechseln
I spilled water on my laptop, now it does not charge at all?
After I spilled water, I cleaned with paper towel. It was working fine , I still turned it off, now I was going to use it, but when I plugged the charger it just does not work. The light does not turn on to show that it is charging? So the laptop is not turning on because of low battery or I dont know if somethings wrong with it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Liquid damage can be tricky to repair. Depending on how long the liquid remained in there and what it damaged, you may need to look towards data recovery by a specialist unless the hard drive is removable and not soldered in. With any form of liquid damage to any electronic, it is best to seek out a professional’s help to open it up, and perform the necessary repairs.
Here’s a video explaining why and what you should do. Jessa from iPad Rehab is a renowned specialist in the repair industry. It’s lengthy video but I highly recommend watching some of it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Nirmal Thapa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 3,946
