Hover-1 pioneer doesn't charge.The charger light is always green. help
Recently bought the Pioneer scooter and it does not charge. The light on the charger remains green. What can I do?
Ist dies eine gute Frage?
i had same problem i wiggled it so it was in the sweet spot 4 red. my positve connection had rattled loose. i removed charging port from inside deck and sautered connection..or u replace
War diese Antwort hilfreich?
It is generally not recommended to attempt to add voltage to a dead battery to get a charger to recognize it. This is because a dead battery is likely dead for a reason - it has lost its ability to hold a charge due to internal damage or chemical changes. Attempting to force the battery to take a charge by adding voltage can be dangerous and may result in further damage to the battery, or even cause it to explode.
If you are having trouble getting a charger to recognize a dead battery, there are a few things you can try instead:
Overall, it is important to exercise caution when dealing with dead batteries and to always follow the manufacturer's instructions for charging and maintaining them.
If you can add a charge directly to the battery for a few minutes and then restore the battery, and use the OEM charger and it should recognize the battery and start charging
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 698
