Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
Sound problems with I phone?
Heres the problem: I did an update for my iphone using a usb cable and itunes on my computer. Once the update was finished, I unhooked the device. Every since then, my phone has been saying "this accessory is not optimized for this device" and I can not get the volume to work right. When I try to change the volume, it is blank under the word "ringer" and the speaker on the screen. Does anyone know how to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This can be either a Hardware or Firmware issue. You are not alone as there are hundreds of other iPhone users experiencing the same issue. Try reading this on an apple forum. Some possible fixes include -
- Plugging earphones in and out of headphone jack about 20 times. Some iPhones are shipped in "earphone mode" and need to be reminded that THEY ARE NOT
- Clean out dock port (possible dust has gotten inside and corroded port making iPhone think it is connecting to something continuously ) and completely restore iPhone. Use a dry toothbrush (something small with bristles to do the job) or dry compressed air. DO NOT BLOW on it with your mouth as saliva may get into it and make it worse.
- Disconnect the battery for several seconds and reconnect, this will physically reset ALL electronic parts of the iPhone. Repair Manual HERE.
- Upgrading to the new/latest iOS
If none of those options have worked then you will need to either take your iPhone back to apple for a replacement (if still under warranty) or replace the dock connector, Repair Manual HERE
Hope this helps :)
iPhone 3GS Akku Bild
Anleitung
iPhone 3GS Akku tauschen
Schwierigkeitsgrad:
Mittel
20 - 30 minutes
iPhone 3GS Dock Connector Bild
Anleitung
iPhone 3GS Dock Connector Replacement
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Steven Kelley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 464
