Zum Hauptinhalt wechseln
Intel Core i5 (5th Gen) 5200U / 2.2 GHz Max Turbo Speed 2.7 GHz Processor 6GB RAM, 1TB HDD 15.6" HD Display (1366x768) Resolution Integrated Intel HD 5500 Graphics
1 Fragen Alle anzeigen
Screen Upgrade (Higher Resolution LCD) for ASUS A555LB Laptop
Hi!
This probably won’t elicit a definite answer since this is about a specific part replacement, but I am still interested in your views or opinions (and why so).
I have a ASUS A555LB-XX410T laptop with a burnout spotty screen with the following specs: Screen Size 15.6 inch, Back Light LED, Connectors 40 Pin Socket, Resolutions & Inch 1366 x 768 (HD). This is the stock screen.
I am thinking of replacing it by ordering a different higher res screen ( FHD 2K 1920x1080 ) (pic below) with same dimensions and no. of pin connectors.
Question: will this work or will it be money gone down the drain?
Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Unless the video card / GPU / chipset supports it, waste of money.
Update (02/01/2020)
Reading online I found both the 940M and Intel 5500 supports 3840 x 2160 so you should be good to go with an upgrade, all else being equal (like you said, power, video connectors, etc).
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
This laptop 15.6" at 1366 x 768 pixels (stock) with 5th gen Intel® Core™ i5 has the following: NGeForce® GT 940M and the onboard Intel HD Graphics 5500.
Do you think this is possible?
von
Antwort hinzufügen
raynerstuelgalid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 252
