Zum Hauptinhalt wechseln
The ASUS X751L is a large screen (17.3 inch) fourth generation i3 dual core laptop released in 2015. Identified by model number X751LX-DH71.
11 Fragen Alle anzeigen
Can I install a touch screen into this system
broken screen on my asus i found a touchscreen same size different pin question i have is will the current mother board support touch? can i flash bios or something to enable touch. some1 please guide me in the propper direction ty
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@petercw Anything is possible so you can always try but we can’t answer that unless we see what board (connectors etc.,) you have.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
ty i will post it when i get home i currently use the system in my living room conected to tv. do i have to open up the case off or is it in system info or in bios maybe?
von
Th eboard number may be in the system info. Most commonly would be that it is not compatible since the hardware requirements are different.
von
the mb is a X751LAB i dont really care if the touch works at this point but under system settings it says touch not enabled
von
Antwort hinzufügen
Peter W wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 106
