Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
NFC Not Working After Rear Replacement
Hi All,
I have an ongoing issue with all iPhone models where NFC won’t work after replacing the rear case. In some cases, swapping out the NFC antenna works however not always.
When changing the antenna doesn’t work, is there something else I can do, a component on the case that can be added or replaced? Is it an insulation or grounding flaw with aftermarket cases? If so, can it be remedied?
On the devices in question, NFC has been tested and proven to be working before the swap and again when the board is transferred back to the original case.
I’m grateful for any help or suggestions, thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
I decided to tear apart a case to see if there is anything in the fabric of how it is constructed…
[image|2007626]
[image|2007622]
The screw that grounds flat to the back of the rear seems really straight forward and doesn’t connect to the plastic antenna band. It also seems that the end that connects to the top edge also has no special make-up.
Still interested in hearing other people’s theories…
von
I guess it goes down as one of those unsolved mysteries…
von
Einen Kommentar hinzufügen
3 Antworten
after have you tried replacing the NFC IC chip?
LINK
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
No because if I put the board back in original case the NFC works, the issue is with the new cases rather than the board. Thank you :)
von
did you ( or are you able to) check the new case with a another iphone 7 if it is working
von
Yeah, I tried the case with different boards so its definitely isolated to the case.
von
I think it is a grounding flaw with aftermarket cases , not only problem with NFC but sometime also other issues.
Bewertung 0
1 Kommentar:
Yeah, it seems that way to me. I did wonder if a slither of grounding tape could help the issue but thought it might cause more problems than it solves.
von
Bewertung 0
Antwort hinzufügen
All Seeing Aye wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 247
