Not seeing 128 gb SSD from Fusion Drive after upgrading HDD to SSD
Macmini6,2 non-server (2.6 GHz Core I7) with 1 TB Fusion drive.
I upgraded the HDD in the lower bay to an SSD and installed Mojave on the SSD. That all works fine, but in disk utility I don’t see the 128 GB SSD that should be part of the Fusion drive.
Instead “diskutil info -all” reports a 1 TB drive as disk0, located in bay “upper”, with “Solid State: no”, so a rotational drive.
So I’m baffled. I did not have a Macmini6,2 server model. It always reported a capacity 1 TB Fusion drive. I never saw a second HDD in disk utility.
The HDD that was in the lower bay is now sitting in an external enclosure and contains all the original data I expect it would.
Anyone have any thoughts about what might be going on here? If you split the Fusion drive, what does diskutil report as the location for the SSD?
Ist dies eine gute Frage?
