Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz), 2,5 GHz (Turbo Boost bis zu 3,7 GHz) oder 2,8 GHz (Turbo Boost bis zu 4,0 GHz) quad-core Intel Core i7 Prozessor mit 6 MB geteiltem L3 Cache.
774 Fragen Alle anzeigen
The battery I ordered can barley hold a charge.
I purchased the battery replacement kit and installed the replacement battery and it will not hold a charge. The first time I charged It completely and let it sit for 3 hours. I started using it and it seemed fine. I turned it on for the first time after installing the battery and it said 98% or 99%. I was on it for about 10 minutes and then left. I came back hours later and the battery was dead.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Many generic batteries are of very low quality. This includes internal circuitry(inside the battery that regulates and communicates with the device),and the quality of the battery itself. This is insanely common for crappy eBay batteries from Hong kong(this happens ALL the time).
It definitely sounds like a bad battery assuming that this never happened with the old battery. I’d get a new one and make sure it is a reputable brand.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I got the battery from the IFIX Kit. Do they give refund or send another replacement?
von
If it’s defective,which it is,yes.
von
Antwort hinzufügen
Leonard Acolatse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 39
