Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2010 / 3.2 GHz Core i3 oder 2.8 & 3.6 GHz Core i5 oder 2.93 GHz Core i7, ID iMac11,3
382 Fragen Alle anzeigen
Unexpected Shut Down after RAM Upgrade
After purchasing 16GB (4x4GB PC3-10600 SODIMM) of RAM from OWC and installing, the computer seemed to be operating fine. The first unexpected shut down occurred about an hour after the install and has kept happening intermittently since then.
I’ve used disk utility to confirm the drive is in good working order and installed all possible operating system updates. Any suggestions??
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Take the SO-DIMMS out and carefully wipe the contacts with a new pink pencil eraser (not dried out) go with the grain of the pins one stroke per pin to make sure there is not oxide build up, then use a cotton swab with reagent grade 85% isopropyl alcohol.
Try only installing two SO-DIMM and then try the other two.
Otherwise you’ll need to return the RAM to get another set.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you thank you thank you!
von
@princeunicorn - Did cleaning them help?
von
It did indeed! I ended up using an eraser first, followed by the rubbing alcohol. The computer seems to be running perfectly.
von
Antwort hinzufügen
Luke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 255
