Zum Hauptinhalt wechseln
Das Lenovo IdeaPad 310 Touch-15ISK wurde im Juli 2016 veröffentlicht. Das Lenovo IdeaPad 310 Touch ist für Multimedia-Anwendungen spezialisiert.
Why won’t it start up?
So I turned my laptop off last night. This morning when I turned it on, it started up, then went straight to a “Choose an Option” page. My two options are troubleshoot or turn of PC.
When you click on troubleshoot, 6 more options are given.
The first one is system restore. I tried that, and a error sign comes up:
Clicking close takes me back to the original page.
The second option restarts the computer but says they couldn’t fix the problem.
The third option give me two more options: to uninstall latest quality update or uninstalling feature update. Neither of these are successful.
Option numbers 4-6 - I don’t know enough about to work with them, however 4 is some sort of coding.. 5 you need a cd in the drive to set up a specific system and 6 restarts the computer and brings you to another page which I also don’t know anything about.
Not sure what else to do, but I’m sure someone can help me out somewhere!
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You probably have some corrupted system files. Sometimes the “Start-Up Repair” option needs to be run 3 or 4 times for it to work and even then says it cannot fix it and then boots up fine the next time. Is does this because it may only fix some of the corruption on the first, etc. pass so it takes a few tries to get it all. I have experience this problem a number of times.
War diese Antwort hilfreich?
Bewertung 1
If your laptop is showing no signs of life and refuses to turn on, use this Lenovo IdeaPad U530 Touch Does Not Turn On problem page for possible causes and solutions.
Bewertung 0
Antwort hinzufügen
Computes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 989
