Zum Hauptinhalt wechseln
Das Betriebssystem von Apple für Ihre Mac Desktop-PCs und portablen Computer
Trying to install El Capitan on iMac
My MacBook is running Mojave and I need to instal El Capitan on my iMac (what was on it before I needed to replace a bad hard drive).
I can’t get it to download using my MacBook through legitimate Apple sources.
HELP! That link Aaron provided is from Apple and since I am running Mojave I can’t download it.
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
So if anyone had this same problem and could help me before I pull ALL of my hair out that would be greatly appreciated!
von
Same here, any luck?
von
did you get to the bottom of this? im in exactly the same situation
von
Einen Kommentar hinzufügen
1 Antwort
Depending on the age of your iMac you should be able to install your new SSD into your system and then run the Internet restore using the start up keys: Command (⌘) & R keys
Reference: About macOS Recovery
To gain access to the older macOS’s use the startup keys Shift & Option-⌘ & R keys
Reference: Reinstall from macOS Recovery
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
amanda819 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 627
