Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für die fünfte Generation des Honda Civic, die erstmals Ende 1991 auf den Markt kam.
Radiator fan not turning on?
Hey guys I think I have a more complex problem or I have over analyzed my situation with my 1992 Honda Civic 4 Cylinders 1.5L MFI SOHC
Car Overheats after about 5 to 10 minutes of driving. Radiator fan never engages to turn on, I also noticed it takes the coolant but the radiator fan still does not turn on. Checked the fan switch by bridging the current and fan turns on.
I replaced following:
cooling fan relay
temp sensor
fan switch
thermstat
I checked the other fuses underneath the hood and they were all good. Not really sure where to go from here. What are your thoughts
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Alejandro Garcia hat is the exact year, engine size and model for your Civic? That way we can chase the wiring and hopefully get you a good answer.
von
1992 Honda Civic 4 Cylinders 1.5L MFI SOHC @oldturkey03
von
Einen Kommentar hinzufügen
1 Antwort
check the pigtail on the thermo Switch next to the to the Thermostat housing for loose wires
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Alejandro Garcia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 955
