Start vehicle it runs for a while the shuts down, have to wait for a
I have a 1997 grand caravan it will start but after driving a little while it shuts down I have to wait about a hour before I can start it again
Ist dies eine gute Frage?
The fuel pump is going out most likely. I owned two of those vehicles and that is a common failure. It requires dropping the tank to replace it so it is a fairly pricey repair and not a job most DIY’ers are advised to tackle. I did one on the first caravan I owned. Remove battery ground strap before attempting tank removal!!! Keeping sparks and hot incandescent lights away from gasoline and fumes cannot be stressed enough!!!! You will likely need a second person to help you lift and position the tank when reinstalling. Link for fairly comprehensive tank removal procedure
War diese Antwort hilfreich?
Tengo el mismo problema solo que al checar la chispa de la bobina se pierde, deja de alimentar el sistema de distribución.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 75
1 Kommentar
scooby1846 sounds like a fuel issue. what engine size does your GC have?
von oldturkey03
