Zum Hauptinhalt wechseln
Vierte Generation des iPad 4s mit CDMA. Verfügbar in 16, 32, oder 64 GB Versionen. Modelllnummer A1460.
19 Fragen Alle anzeigen
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I don’t know what I did different, but I got the display to work.
Thank you for the replies
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
War diese Antwort hilfreich?
Bewertung 1
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
Bewertung 0
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
Bewertung 0
Antwort hinzufügen
sunruh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 91
