Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
Cannot go into landscape mode - faulty accelerometer?
Hi all
I have a rare problem on my new iPhone 3G 8GB Black model, it cannot go in landscape mode even it is tilted the right way (I have another one to compare ;), in Need For Speed Shift it is turned all the way right all the time, like the sensor is stuck all the way on the right side. It cannot swith in landscape in any application. Strange thing is that when you type something and you shake it to Undo, it DOES pop out the Undo option! How the hell is that possible, isn't the accelerometer doing the Undo option too?
It is 3.1.2 FW, latest BB, I tried several Restore option to no avail. Tried hard reset also (keep pressing both Home and Power buttons), nothing, still the same.
My question is, can it be fixed anyway?
It is the new one, I unboxed it personally. I don't have a warranty :(
Thanks in advance
Alf, Serbia
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I got lucky! I left iPhone in the box in sleep mode and it recalibrated acceleometer and it is working now!
So solution for this is:
leave iPhone on flat desk for a night and the chip will recalibrate itself, if the chip is not faulty ofcourse.
Hope this helps
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
You should accept this answer! It will let future users see that it's easy to recalibrate and they don't have to solder a new chip on ;)
von
Yeah I'm not convinced accelerometers are as accurate/reliable as people claim, I hope they improve, but for example, my G1's accelerometer stopped working one day, but then was restored by the next software update. Hopefully they will get better.
von
kudos, you get an up vote from me.
von
From what I know, the accelerometer is part of the logic board, in which case it's not worth and very difficult to repair. You'll probably either have to get it replaced, professionally (and expensively done) or live with it.
Bewertung 0
1 Kommentar:
Hi, thanks for fast response ;)
I did some searching and found out that you are correct, it is the small chip on mainboard that is 3x3mm in size with 16 pins to solder back on mainboard. My luck is I have a friend who can replace that chip for me ;) The price of the chip is only 6-7$, so I think it is worth a try, what you think?
Regards
Alf
von
Ok, I ordered the accelerometer chip:
http://www.st.com/stonline/products/fami...
It will arrive in a month :(
It is around 20$ which is not a pocket break. I have a free soldering man, so it is a go.
Will let you know how it went in the end.
Regards
Bewertung 0
1 Kommentar:
That's great you were able to do your own research and luckily have access to free soldering. Just remember to be and tell your friend to be careful. Will minute soldering such as that, it's fairly easy to destroy some integral component on the board.
von
Antwort hinzufügen
Alf wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 14,257
