Zum Hauptinhalt wechseln
Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
40 Fragen Alle anzeigen
does my hp g60 230us laptop have both the lcd power inverter cclf?
I just looked up my lcd sreen for my computer and I know what I have to do but my question was or is can my power inverter that powers my lcd screen and backlight be replaced or do I have to by a new computer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
In the case of your computer it is necessary to replace the display inverter, release the display inverter 1, located at the bottom edge of the display assembly, from its mounting clips. The maintenance guide is available here. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Yes. You can replace the inverter. Sometimes its behind the LCD screen or in the frame. ( you would need to know if the inverter is the problem, assume you already do)
Bewertung 1
Antwort hinzufügen
Tj Jones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,666
