Zum Hauptinhalt wechseln
Whirlpool Gold Series Geschirrspüler können anhand der Modellnummer WDF750SAYM0, WDF750SAYM1, WDF750SAYM2 oder WDF750SAYM3 identifiziert werden.
Why is my display reading 1H and flashing occasionally?
I have. Whirlpool Gold Quiet Partner 3
Model # GU2400XTPQ7
Age unknown for sure
Ran a regular cycle like always last night, this evening when I come home the display is reading 1H and blinking every once and a while. When I tell it to cancel, it starts running a two minute cycle but doesn’t sound like it’s producing any water. I ran a regular cycle to try to clear it. Dishes were wet by the end, so it can produce water, but the 1H came right back after the cycle.
How doi do I fix this, or is the machine just toast?
Update (03/11/2020)
Model # GU2400XTPQ7
New update:
I did the sani-rinse/heated dry combo and it worked temporarily.
it gave me the code d3, and did a countdown from 7, flipping through different settings until it turned off. However about 7 hours later it randomly kicked on for about 1 minute with nothing on the display and just now the 1H was back on the display even though no one has touched it.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi @kallile ,
Check if there is a "tech sheet" taped behind the dishwasher's kickboard (toe panel?)
If there is it may help you to narrow down to what the problem may be.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @kallile ,
Did you try pressing the Cancel/Drain button to clear the code?
Here’s an image taken from the user manual that describes Delay Start
(click on image to enlarge for better viewing)
War diese Antwort hilfreich?
Bewertung 1
@kallile we really need to know what model this is. the H1 could possibly be an 1H which could make this a 1Hour delayed start. In the meantime try a reset and see if that changes anything. This should work for your machine:
  • Crack the door open by about 2 -3 inches
  • Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the control panel in quick sequence to enter diagnostic mode.
  • Close the dishwasher door and engage the door latch.
  • Wait 10 seconds before pressing the "Cancel" button to reset your dishwasher.
Bewertung 0
Antwort hinzufügen
Jill Wines wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,791
